Down pipes
dinojc86
New York
Fitment is great and its probably the best bolt on for the car, up there with the intercooler with or without a tune performance wise
Do you do the install yourself, or what did it cost to have it done?
Do I need to replace any other stock sensors, etc............
Your help is appreciated.
I plan to do the intercooler too, I'm on the Gearhead wait list.
yaycandy
Aerospace Engineer
Hanover, PA
Yea the install wasnt too easy. Pretty tight working areas and the front turbo you gotta have it on the threads and like pulled to the end of the threads to put the nuts on as the one is tight to get on when the pipe is fully against turbo. Ill post pictures if i can find them.
Did it on the floor as my lift wasnt working yet, had to remove passenger side wheel for better access to rear turbo. Still better to have a buddy with you. Was thinking it would be better to remove an engine mount to drop it down alittle further but i didnt try it so i dont know if it will help
Some nuts came out with the stud as you can see on the one picture with the turbo with no pipe on it. Took a few hours on the floor. Easy process its just rusted bolts and hard to find good angles to get the nuts off without breaking anything. From what i can remember, did it about 20 months ago.
All sensors fit fine like its stock, just the downstream o2’s dont like not having the cats there so either a tune will turn the code off but you will never reach obd readiness. Or they make the adapter thing angled best for our platforms situation and the code shouldnt come on with those installed and i guess obd readiness for catalyst will finish
08E84AA9 7B7E 4053 AA3C CCA66AE8653B 139938B2 D83A 433E A4C0 85E5093A1B47 62C4531C 6A69 4B29 95EE 3FB5FBB2C073 C2304D0A 1E23 4A71 89A0 7AA9C5648878 084A58BA 0B19 419B B9C3 8E833AACB036 3112447E B578 488A B299 AEBF4601E62C 77C567DF 6AE1 4E5A B6C6 44E7283E9634 CDF00006 D2EB 4CB1 8EDD 406CE397414A 10858FFC 37EF 4C04 BD08 349D64130C57 5C6CFA6E 1DF5 4A91 848A EEC8AB8112A0 9C744603 B47D 4E31 AF0C 7F101A64DA48 39484565 8779 4D9D B19A 87B49A428002
Wsho
Sacramento California
Just ordered PPE downpipe catted being made approximately three or four weeks delivery I did order those adapters for O2 sensors which I don't need no more since I'm going with catted and not catless
1582735128662 1987773842 1582735159973 1942837647
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
Was thinking about getting these down pipes what do y’all think ?
https://www.carid.com/2013-ford-tau...e-360104170.html?parentsubmodel[]=ENGINE|3.5L
Have you checked out our downpipes we have available? We use them on every build that we do in house, the fitment is great, cost is on the affordable side and we have both options the standard high flow catted version and our offroad race only applications! If you would like some more information feel free to send a PM or call me at 313-561-5500 ext 123 my name is cody and ill be glad to assist! Check out the links below: https://www.livernoismotorsports.com/product/LPP101115
https://www.livernoismotorsports.com/product/LPP101114
bpd1151
Lurking Around
SHOcago 'Burbs
@SM105.....
Reference the post before yours, it's stuff like that, that really pains me for the forum staff to install an "UNLIKE" button.
Couldn't agree more with your sentiment and timely warnings to any potential new customers of their's, as well as a reminder to any current customers remaining (can't imagine given all that's occurred with them within the last couple of years, anyone would want to stay) but a warning rather to......
STEER CLEAR!!!!
Ouch....what have I missed?
LMS is trying to get back into the good graces of our community after they screwed up a bunch of tunes with shifting issues and massive fuel pressure problems on the 2013+ cars. Their claimed only fix was buying their Firestorm HPFP upgrade. Numerous other tuners called them out (Matt from GH, and Brad from AJPTurbo namely) on the BS. Both have proven safe tunes that make more power on the STOCK HPFP then LMS. It is all documented.
@SM105.....
STEER CLEAR!!!!
Depending on circumstances and if you are okay with it, I will starting posting your thread as well.
Zpak
Es Aich Oh!
The region, Indiana
LMS is trying to back into the good graces of our community after they screwed up a bunch of tunes with shifting issues and massive fuel pressure problems on the 2013+ cars. Their claimed only fix was buying their Firestorm HPFP upgrade. Numerous other tuners called them out (Matt from GH, and Brad from AJPTurbo namely) on the BS. Both have proven safe tunes that make more power on the STOCK HPFP then LMS. It is all documented.
Come on now, don’t forget about the blame that needs to be placed on all those car owners. They were to lazy to turn traction control off every time they went for a drive, didn’t overfill their transmissions, and chose to drive when it was way to cold out.
Come on now, don’t forget about the blame that needs to be placed on all those car owners. They were to lazy to turn traction control off every time they went for a drive, didn’t overfill their transmissions, and chose to drive when it was way too cold out.
I know, how dare them!
