Door Locks not working?
black93sho
Ohio
The door locks in my 93 have not been working in a while and I think its about time I try and fix them, so I have a few questions. Would a bad door lock actuator make all of the locks not work? And is it a possibility that the box in the trunk of the car for the door locks went bad?
oh_SHO
Ohio
one bad actuator wouldn't make the rest of the locks not work. It could possibly be the box in the trunk. I assume you've checked the fuses? Is anything else not working?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
The door locks dont work when you try_____. Pressing the buttons inside the car? Using the remote keyless entry? Using the keyless entry on the door?
Mine dont work sometimes when I use the buttons inside, but the locks work fine when I use either keyless entry system. This is b/c my buttons on the doors need cleaning I believe.
black93sho
Ohio
My car doesn't have the keypad, it has an aftermarket keyless entry system. But the locks never work. The keyless entry wont lock or unlock the doors. But I can unlock them from the passenger side unlock button. But the drivers side Button doesn't do anything.
