door light stays on
shoxtreme
Utah
Some times the door light in the cluster and the overhead lights stay on when all doors have been closed and i'm driving down the road. Some times it turns of and the doors lock but most times it stays on after all the doors have been re-shut over and over again. There was (or still is) a aftermarket alarm on it but it wasnt done proffesionally would that have anything to do with it? Thanks tj
ENDEE666
LI, NY
I get this sometimes too. Do you also get the dash light indicating a door is open? For some reason my sensor doesn't register sometimes... I just shut the door a few times & its usually good.
MichaelH
ZEXman
Schaumburg, IL
This just happened to me a couple of months ago. I think when things started getting cold and parts start sticking. If you look, you will find threads addressing this. The one I found worked. It's probably the sensor in the driver's door, since that one gets used the most. It gets stuck/corroded. Also go to V8SHO.COM and search. You will find photos of the parts of the door latch that need lubricating.
The answer is to soak the area with electrical contact cleaner and/or WD-40. I used both. I removed the door panel and cut out the plastic waterproofing so I could get a good shot. I then emptied a small spray bottle of electrical contact cleaner from Radio Shack and WD-40 until it started dripping out the bottom of the door.
The fix was not instantaneous, as the stuff has to soak in. It started improving the next day. I would say the door switch was back to normal within 72 hours.
avocadoman1
Channel Islands, CA
this thread will give you details on how to fix...
interior light stays on
you'll need WD-40
poffffd
