door fitment
95mtxSHOowner
North Branch,minnesota
i have a 91' sho and i am wondering if doors off of any taurus or sable will fit from 89-95? or is it specific to 89-91 cars that will fit mine
thanks in advance
mike
jelloslug
Digital
Greenville, SC
If you are removing the drivers front door you can unhook the wiring right at the door jam. There is a ********* connector in the jam, start by removing the cap on the top, then use a 10mm socket and unscrew the bolt that was under the cap. The lower part of the connector should be moving by this point, unscrew it all the way and then pull down on the lower half and it should pop out.
Minnesho
i was wrong
MinneSHOta
All the doors have plugs to disconnect the wiring, without fishing it all through the door. the drivers front is on the door with the 10mm nut as jelloslug mentioned, the rest have the harness right inside the pillars.
IIRC, first gen sable doors are completley different. it will physically bolt on but they don't have the body line the taurus has. also some sables had lowerclading as well, and the mounting points were almost identical to the SHO. or else you'll just have to drill holes. i have a passenger front and drivers rear from a 92 ... want them?
95mtxSHOowner
Aaron
you aked me that the other day didnt you ? i wasnt thinking i guess
Yes i will take them from you if you dont mind. what kind a shape are they in? i want to meet up with you very soon to get the bumper covers to please.
and my brother really wants to get that sunroof shade to putin his car.
we are going to the exhaust shop tomorrow to build the new y-pipe for his car if you want to swing by i can give you my cell # to call before you come to make sure we are there
