Dome light removal
90sho
New Jersey
I have a 92 with a sunroof and i want to remove the dome light. How do i do this without breaking it :thumb:
ohioshodude
SHO'ld fogy
delaware, ohio
push in on both light as if you were turning them on. hold them up, there should be a small void between the two lenses. with a very small screw driver pop either lense out. becareful, these are weak, puy one side then the other. then you can pop the other one out very easily. then there are two screw up at the top right above the lights. unscrew those and pull the unit down a little and back toward the sunroof. that all there is too it.
ohioshodude
SHO'ld fogy
delaware, ohio
thats the only way to do it with sunroofed cars without breaking the lenses. my explaination is for the console over the sunroof motor between the visors. if you talking about the rear lamps those are have a different way of removing them.
bmytych
