:shakehead The radiator comes out through the bottom of the car,It's not very fun to replace,even when car is on a hoist.It's enough to make you feel like :vomit:. Special Tools needed are trans line quick disconnect tool and a/c gauges.the a/c condensor comes out with radiator.
Last time I replaced one it took a few hours.
But if you're into it here's the procedure from the Service Manual
MIke
Removal
CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs, the service interval of Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
Disconnect battery ground cable (14301).
Remove battery (10653) as described in Section 14-01.
Remove clip retaining contant control relay module and position module aside.
Remove battery tray (10732) as described in Section 14-01.
Remove radiator cap (8100).
Raise vehicle on hoist as described in Section 00-02.
Remove radiator splash shield.
Drain engine cooling system as described in this section.
Remove the radiator mounting bracket assembly.
Remove lower radiator hose (8286).
Partially lower vehicle.
Remove upper radiator hose (8260).
Remove radiator overflow hose (8075).
Remove upper A/C condenser core retaining bolts.
Remove upper transmission oil cooler tube clips.
Remove lower transmission oil cooler tube (7C410)(EPN=7C410)using 3/8 Inch Fuel Line Disconnect Tool T90T-9550-C.
Raise vehicle on hoist.
Remove lower transmission oil cooler tube clips.
Remove transmission oil cooler bracket and position transmission oil cooler aside.
Remove lower A/C condenser core bolts and position A/C condenser core (19712)aside.
Remove radiator support bracket.
Remove radiator (8005).
Installation
Position radiator (8005).
Position radiator support bracket and tighten nuts to 8-12Nm (71-106 lb-in).
Position A/C condenser core (19712)and tighten lower A/C condenser core bolts to 5-7 Nm (45-61 lb-in).
Position transmission oil cooler tube and install transmission oil cooler tube bracket. Tighten nuts to 5-7Nm (45-61 lb-in).
Install lower transmission oil cooler tube (7C410)(EPN=7C410).
Install lower transmission oil cooler tube clips.
Install lower radiator hose (8286).
Install radiator mounting bracket assembly. Tighten bolts to 8-12Nm (71-106 lb-in).
Install radiator splash shield.
Lower vehicle.
Install upper tranmission oil cooler tube (7C410)(EPN=7C410).
Install upper transmission oil cooler tube clips.
Install upper A/C condenser core retaining bolts. Tighten bolts to 5-7Nm (45-61 lb-in).
Install radiator overflow hose (8075). Tighten clamps securely.
Install upper radiator hose (8260).
Install battery tray (10732).
Position constant control relay module and clip securely.
Install battery (10653)(EPN=10653).
Connect battery ground cable (14301).
Fill and bleed cooling system as described in this section.
Start engine and inspect for leaks.
