I definitely don't have time to replace the clutch before the Dyno (noisy TOB) so I've decided that the extreme mounts should be the least I can do before saturday.
I know the subframe does not have to be dropped in order to install the front motor mount as long as the engine is properly supported. However, SHOTIMES wasn't clear as to whether or not the subframe needed to be dropped to access the rear mount.
Also, is it absolutely imperative to remove the lower radiator hose? If so how much coolant is expected to come out that I have to replace...a gallon?
Any input is appreciated. TIA!
