LIZARDKING
Have had SHO for 2 + weeks, haven't been able to fix EATC problems. The blower fan stays on all the time. If I push off or move the thumb wheel for the fan, the fan motor will change speed but ends up on high. The fan will not shut off, even when I pull the EATC out. I pulled the blower control module from behind the glove box, but this seems to be an electrical problem, and that unit has no electrical connections on it. There must be a electrical switch for the fan motor? The EATC that came with the car shows no error codes. The EATC I got from the J-yard flashs between error codes 03 (in car temp sensor open or short) and 04 (ambient temp sensor open or short). Seems neither of these would affect fan operation. Unless someone can tell me different I think the next move is to locate the fan blower switch and change that. I hate just swaping components until I find the problem, that wastes alot of time and money. Haven't located a shop manual yet, makes it alot harder.
