Differential Pins
PacoLoco
Chicago, IL USA
Just a quick questions...where would I buy differential pins? Any local parts store sell them? Also, input shaft seal is a dealer part only or do parts stores sell? Thanks in advance.
TYSHO
Earth
Seals are available at parts stores, Timkens are the lowest price.
What do you refer to as pins? The actual roll pins or the pinion shafts? Roll pins can be found at local hardware stores and pinion shafts are not available anywhere.
PacoLoco
Chicago, IL USA
I am refering to the roll pins. That is if those are the pins that should be replaced whenever taking the tranny apart.
TYSHO
Earth
If your differential hasn't exploded, those are the roll pins you are talking about. I have some stainless steel ones for cheap, if you can't seem to find any. :thumb:
AREA 91
PA SHO SHOP
Area 91
I also have about 50 FORD roll pins. P.M. if interested.:thumb:
theaterkeith
Florida
If you are taking it apart i would use transfer punches instead of rolled pins, just went throught the whole exploded tranny game.
DSCF0325
DSCF0327
We used a transfer punch, drove them in and staked the holes over to keep them from walking out, got photos of them to just not availible ATM will post later
TYSHO
Earth
Don't underestimate the strength of roll pins...
AREA 91
PA SHO SHOP
Area 91
That Photo makes me want to cry!!!!
That's 1 less MTX4 in this world!
Don't do burnouts people!!!!!!!!!
TYSHO
Earth
You can do burnouts with these! :evilgrin:
theaterkeith
Florida
Wasnt a burn out, was shifting from second to third on on ramp, roll pin walked out about 1/2 way and sheared
Minnesho
i was wrong
MinneSHOta
when my diff pin finally blew through the case i was just cruising down the interstate. i noticed it felt like it was slipping a couple days prior, was probably just the pin hitting the case.
theaterkeith
Florida
if that makes you cry you should have seen my crank pulley from P.O. not tightening crank nut enuff, Grove in crank pulley was V-ed out and key was almost sheered from pulley rocking back and forth on crank, Luckily a busted water hose save me from that demise since we had shroud pulled off we decide to change T belt cause was unknown when last changed, and you could rock pulley back and forth with your hand
TYSHO
Earth
Gotcha, I just saw the arrow pointing up and mine was the first. :thumb:
jedhead
westminster,ca
Quaife is the best way to go. Not only does it make your diff bullet proof, your car will handle much more like a RWD when you power out of the corners. IMHO the Quiafe is the top 3 mods to do.
1. Y-pipe for MTX
2. Subframe connectors
3. Quaife.
Bob
AREA 91
PA SHO SHOP
Area 91
Quote:
Originally Posted by witsimpala
Get a Quaife, or get a different car.
Well, get a supercharger, or get a different car!
I'm working on it.:evilgrin:
