i blew the starter that came on the 95 because of a bad sylanoid, now i just replaced it with the starter from my 92 but the third wire (not the direct power from battery or the ground) connects to the starter differently. the 95 used a ring end and was secured with a nut on a stud. the 92 starter uses a spade terminal on on the starter. is it ok to just splice a new end on the wire and and roll with it. i also noticed that the wire itself is much larger on the 95 as apposed to the 92. will it still work or am i just going to fry it?
