gmail
Well-Known Member
i picked up 12 of these today.. make sure you get this number that is on the injector 0280155715 they are light blue but also they only come on the duhtech motors and there is 2 different kinds.. make sure its a early duhtech motor and double check the connector make sure its not the tiny plug with 2 little wire terminals on the injector... make sure its the fat one the SHO uses.
EDIT: another clue to it being the right one is they correct one will use a metal clip to hold the plug on.. ill post pics of them when they are done in their ultrasonic bath
i havent installed them on the car yet because i am giving them a ultrasonic bath.. i plan to on probley tuesday ill test them out before and after and i also got a wideband on the car so ill know how it behaves if they are safe and what not.
this difference shouldnt be bad its only like 1.3 lbs difference and worst case it would be a tad richer over stock injectors
