Different Flywheel
Locost_SHO
Scottsdale
Was wondering if anybody knew if the crank to flywheel bolt pattern is a common ford bolt pattern or if it is SHO only. Hoping to use a lighter/different clutch system on a rwd application.
Thanks for any help
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Well you can find 9lb flyheels so you can get light ones. I know of Lupo using a Tilton 3 disc clutch system in his Ranger SHO.
HotRodKid
mmmmm ... turbo
Western NY
theres very few vehicals in general that use a 9" flywheel
just have the stocker lightened, or get a fidenza
Locost_SHO
Scottsdale
Well I've noticed that. What I was trying to do was potentially replace the SHO flywheel with one from a mustang or other ford engine so that I could get a larger clutch with the correct input size and spline for a T-5. And there is a more extensive selection of clutches there.
HotRodKid
mmmmm ... turbo
Western NY
doesnt work, theres not enough room inside the bolt pattern for the bellhousing
mating a t5 can still be done, and its outlined HERE
