Did upper 60k and car dies
boat
Likes blue ones
Tallahassee, FL
If your vacuum system is working correctly, when the IAC is unplugged, the car should die, at least that's what I understand about it. I agree with the above, almost sounds like it is an IAC issue. I am dealing with almost the reverse of what you are. Mine has a vacuum leak, won't stay running with the IAC plugged in. Unplugged, it chugs, and sounds like a motorcycle out the exhaust, then dies after like a minute or 2.
Good luck in your repair, hope you get yours figured out.
eminem3150
FL
Mine does die with the IAC unplugged. Car runs perfect except for the stupid oil leaks. I think my cam sensor is getting killed by one.
fordboy
Indiana
SHO doesnt idle
I bought a 95 SHO and its not wanting to run right its not idling in kills itself and when your driving its lacking power
dan.delargy
