Driving on the eway, in my atx, I discovered that I was driving in 2nd gear. Without coming to a complete stop, slowing down to 40mph, I shifted into Drive, waiting a few seconds and then got back up to speed. The car seemed to shift back fine, but a few minutes later, the car ******, and soon after I pulled off the eway, and when I came to a stop, the engine/car was already off. I tried restarting and it would want to turn over, and when it did there was this loud clicking/rattling metal noise sound coming from seemingly up under the engine bay. Could that have been the teeth of the starter on the flywheel? I quickly shut the engine off, and it wouldn't turn anymore after that, not even wanting to do anything, not even a wanting to sound like it was trying to turn over. Now, it just clicks one time!
Another issue here is that I've had a leaky oil pan gasket for months. It causes smoke from the rear while driving from time to time, but not all the time. When I drove in 2nd gear, the smoke became highly cloudy and much much thicker.....I don't know if 2nd gear makes the oil pressure higher thus forcing more oil to leak through parts of the unsealed oil pan gasket. When I pulled off the eway, I checked my oil level and little to no oil was seen on the dipstick. I put 2 quarts of oil in and the dipstick read Full.
Also, could this be my tranny went out and/or my engine locked up? Help is needed asap! thanks!!!!
***I was driving for a total of less than 10 minutes all while this happened at a high speed (70-80mph). It's hard to get an accurate reading on my tranny fluid level since it's suggested the car be running for a good 10 minutes to get a good reading. As it is now, the tranny fluid level is normal, and the fluid looks very clean!
