Diameter of Intake Manifold Runners
Marccus
California
Does anyone know the outside diameter of the intake maniflold runners (I'm not sure if that is the right term).
These are the pipes that lead from the butterflies to the inlet pipes on the other side with the small spacing in between. They are coupled together with the hose gasket and clamps.
I need the exact outside diameter of the pipes to buy the correct inside diameter of silicone hose.
This dimension is most likely in millimeters
Thanks.
:salute:
bmytych
