Ok here is what i know:
ford diag. shows #3 cyl is not pulling but spark duration is fine.
replaced plugs and wires and plug tube seals as they were leaking oil.
car runs like it's has 3 cyl. slight ticking in engine comp. NO power at all and has been like this for a couple of years.
60K service was done except no timing belt change. car has 91K now.
will be doing a compression test soon to rule out air.
ran into another guy with the exact same problem. he told me his started when he hosed off his engine to clean it one day. i have also had my engine steam cleaned once. any connection?
where do i start to diag this power problem? if spark is OK can it still be electrical?
