Diag code p0411
jimsnorton
ca
Greetings, My '97 has started to throw a P0411 code: Secondary Air Injection Incorrect Upstream Flow Detected- Now my question is, how can I repair it? I will need to get a smog inspection in Oct. so I need to get busy fixing it. Any help will be gratefully appreciated.
jimsnorton
ca
Thank you Stephen. I will be trying to find that relay first. I have an issue with another relay that sticks, forcing one of the cooling fans to run after the the ignition is turned off. I have to unhook this little latch holding a relay box, adjacent to the battery & give it a "flick" against the battery & all's good until the next time I use the A/C. A minor annoyance from a car with 248000 miles. Again, thanks, Jim
djxib
Atlanta
I had a P0411 - the secondary air injection pump had siezed; $125 from Napa. Good luck getting it fixed.
