DevilsOwn Stage 2 kit install in MDesign CAI space completed!
SilverSH0
Update: Second revision in on meth tune by Torrie at Unleashed and the car is really coming alive. Torrie's customer service has been phenomenal as always. I am currently running 50/50 WM coming on at 6psi and full output at 9 psi using a 7gpm nozzle. That being said you can really burn through a 3QT bottle fairly quickly if you are driving aggressively. I found a local source for 5 gallon VP M1 99% methanol for $43 bucks and change, so keeping the gallon jugs I have filled shouldn’t be a problem just have to mix up my own 50/50 blend. Anyway, I hope to have the car dyno’d once the tune is dialed in and will get them posted.
I didn't realize how good of a price I have here. There's a performance shop local that sell methanol for go-kart racing. He will pump it into whatever container I bring him for $3/gallon.
Colorado Springs
That's a good deal, I should be able to find it cheaper but needed to top off the jugs I had fairly quickly. There are a few local race tracks and speedways I could look into even Snow Performance is local, may need to check out the go-kart racing scene as well. Anyway, you really cant beat $3 dollars a gallon. I have a business trip coming up so additional tuning will be on hold for awhile.
Colorado Springs
Not sure, took two days over the weekend working on and off. It will take a lot less time if you have a plan. Making the bracket and mounting the controller toook the longest. It's time consuming but not hard.
Sent from my SAMSUNG-SM-J320A using Tapatalk
10bird
Thanks for the replies and the original write up. Do you still have the template for the bracket?
Colorado Springs
Sorry for the late response. Not sure if I still have it. It's not hard though. Just take you time. I will look when I'm back home in a few days if you would like.
