Detailed Fish tank and fog light Mod
bc1025
Badge1025
Florida
When I first heard of this my interest was high. What info I could find was limited and the SHOsource thread was gone. You old timers know a majority of this and how to, so this is for the junior members.
IMG 0199
Instead of going to the salvage yard, I got what was needed from Auto Zone for about $15.00.
IMG 0168
I bought new 3357 bulbs because mine were getting foggy. The socket is the 85802 for the 1157 bulb. I had to get the 2057's due to no 1157's in stock. Don't forget the bulb grease.
The first step is a pain in the neck. You have three clips on each lamp that hold the assembly in place. *BE CAREFUL the clips are very easy to break. Get extras from the junk yard if you can.
IMG 0185
IMG 0186
The way I did the tops was with a flat head and gently wiggled them until the were loose enough to pull. They usually snap at the top by the slot. I was lucky, none broke, but I had extras I grabbed earlier from the J-Y.
The lowers, I used an old coat hanger. At this point, gently wiggle the lamps until the black adj caps pull free/Straight forward and out.
IMG 0167
Now that the lights are removed, I unscrewed the tanks to be modified. Easier to work on this way. Now is also a good time to restore/clean all the lenses if needed. I was lucky, mine are like new.
IMG 0163
I used a 1 1/4 hole saw to drill out the opening. I picked a spot just above dead center and made the cut. My shop vac nozzle also fit so I could suck all the debris out
IMG 0183
The tank housing is mirrored, which is a good thing.
IMG 0165
http://i295.photobucket.com/albums/mm149/BC1025/IMG_0164.jpg
[ATTACH=full]70358[/ATTACH]
[B]These generic sockets have clips that will hold it in place in the lamp housing. At this point I used some Black silicone sealant to secure and help keep the socket in place.[/B]
[ATTACH=full]70359[/ATTACH]
[ATTACH=full]70360[/ATTACH]
[B]As you can see, they fit in real nice[/B]
[B][I]*OPTION[/I][/B] [B]If you want a real bright light, solder a tab across both contact points on the bulb. It will be insanely bright. Then figure a way to ground it. I didn't. I used one wire for power and the other for ground.[/B]
[ATTACH=full]70361[/ATTACH]
[B]Put the assembly back together and re-install on your SHO[/B]
[ATTACH=full]70362[/ATTACH]
[B]Now is the time to determine how you will power the new lights. I have read that other members had all types of screwy issues. So this step is important. I got my 12v test light out and began to look for the parking light (only) wire, not the blinker. In the wire harness to the front P-light/blinker are three wires. I determined the middle or brown wire was the P-light. the green was the blinker. With a wire couple, I made the connection. * don't forget to run the new light wire into the coupler before you crimp the coupler! I grounded the other wire to an existing ground located on the frame above the radiator.[/B]
[ATTACH=full]70363[/ATTACH]
[B]Now is the time to make sure everything works and causes no un-wanted changes such as blinking or interior light/dash light issues.[/B]
[ATTACH=full]70364[/ATTACH]
[B]If all is good you are about done. The next step is the fog light mod with only P-lights on.[/B]
[B]The fog light mod is very simple and straight forward. The next two images are courtesy of our forum. I thank you in advance.[/B]
[ATTACH=full]70365[/ATTACH]
[ATTACH=full]70366[/ATTACH]
[B]Cut the red wire and cap the end from the harness. Put the red wire from the switch and couple it to the blue/red wire. That's it. I hope this will be help for newer members wanting to do this mod. I think it turned out great and looks incredible at night.
Regards, BC[/B]
[ATTACH=full]70367[/ATTACH]
boat
Likes blue ones
Tallahassee, FL
Nice write up. One can also use the corner lamp (smaller) socket and put in the fishtanks. I believe that was how the original mod was done. I just did mine on my 94 like last week, with the smaller 194NA bulbs, but I do like this one with the bigger bulb in it. :)
Nice job :thumb:
EL SHO
Taco Manager
Monterrey, Mexico
This is a really nice write up!
It got me thinking though if I could install some LED inside the fishtanks and run them like DRLs whenever I put the key in the On position.
I'll make a trip to AutoZone and see if they have any LED strips that can stand 12v.
RonPorter
SHO Club of America
Lake Orion, MI
Those clips are readily available at parts stores. I bought a box of 25 a few years back.
sperold
Last to Know
The junkyard clips you reference are called "Headlight Retainers" and are Dorman Part # 42190, and they are a universal Ford part for 1984 and newer.
lingyuair
