JDLangevin:
There is this stuff at Bond Auto that this guy showed me, he said you drain all your oil, put this in, and let it idle for 5 minutes. Supposedly it cleans out your engine good. He said it is almost like deisel fuel...?
I'm afraid to try it, anyone ever use a similar thing?
Jd,
Back in the old days of small blocks and big gaps, we used diesel fuel to clean out really clogged engines. You old timers will know what I'm talking about when I say really clogged.
The push rod valley underneath the intake would have this thick black crud all over everything; the inside of the valve covers would be coated about a quarter inch thick also. Usually one or more of the push rod oil passages would be blocked or a lifter would be blocked.
We would use diesel fuel as a flush. Buy a ton of cheap oil and half a dozen filters. Drain old oil, put in new filter and fill up with diesel. Idle for 5, drain out black syrup and repeat.
By about the fourth cycle the diesel would start to come out more clear but still dark. Then we would switch to the cheap oil and do 2 more cycles, each time with a new filter.
WARNING! DO NOT USE THE DIESEL OR KEROSENE FLUSH ON MODERN DAY MOTORS WITH THE TIGHT BEARING CLEARANCES. THIS IS FOR OLD STYLE MOTORS.
I agree with AUTOSHO in that I would not put a load on the engine while doing the ATX additive thing though. And I wouldn't use more than a pint per pan full of oil.
Just my .023841298 cents worth. What the heck, I just wanted to be exact. wink
Tom
<small>[ February 02, 2004, 08:53 AM: Message edited by: Off Road SHO ]</small>
