Defrost/floor vents not blowing air
JP Strunc
Nebraska
My 2015 sho’s defrost and floor vents just randomly stopped working today. My dash vents and rear defrost work perfectly fine, but as soon as I turn on the defrost, it only blows from the dash. Same problem with the floor vents. Any help is greatly appreciated!!
I'm not sure how many actuators are in this car but most likely one is broken moving the air flow from one area to another. I know there is a mode actuator but I don't have all the specs to see how everything works together. If it is like most modern vehicles it is tucked into a **** to access space in the dash. See if there are files from a repair manual that have all the actuators for HVAC listed so you can get an idea of location and function.
JP Strunc
Nebraska
Sounds like a pain in the ass. I’ll look into it, thanks
CraxyMitch
Ohio
It's the driver side actuator, it's waaaaay up above the accelerator. You'll hate replacing it. But it's small and cheap to buy a replacement.
Florida
I thought the one above the pedal was for the drivers side climate? isnt the one for vent control behind the radio? I know of 3 actuators, drivers side climate accessible above pedal, passenger climate accessible behind glove box, and vent control deep behind the radio. I could be wrong, I did a little research when I lost AC this past summer.
shootinirons
