Death wobble!
SonicRiot
Handbanana!
CT
I am about to do my outer tie rods and upper and lower balljoints in front because my lane changes are becoming more and more interesting eek! due to bad tie rod ends. Also, my ball joints have excessive play in them, causing a death-wobble. Anything else I should do while I am in there? What are the best parts anyone can recommend...OEM or is there an upgrade such as Moog or whatever? I am planning on upgrading my suspension in as many ways as possible, so a harsher ride is cool with me...but is there an upgrade?
Also, is there such a thing as a front knuckle brace? I would assume no becuase there is a CV joint in the way...
Thanks.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Moog inner and Moog outer greasable tie rod ends.
Moog TPR sway bar bushings, endlinks.
And you might want to consider doing the entire spring/strut install, since everything will be apart shrug
SonicRiot
Handbanana!
CT
Yeah...just did stuts/springs. Wish I had done this then... headbang
Porkchop
The Black Sheep
Virginia
MOOG makes greasable inners????
I have the outers and the SBE's
SonicRiot
Handbanana!
CT
But what about the ball joints? Is there an upgrade or are OEM good enough? shrug
RStalveyARFF
too many shos
Georgetown, MA
the ball joints will actually be lower control arms since they aren't removable. Just get ones that are greasable, they're roughly all the same.
