Death wobble
Laurel
Utah
Help!!! I was driving and at low speeds I have a wobble that you can feel all over in the steering wheel and the floor board. What is going on???
What kind of wobble? What year? You should look at the front wheels obviously, also the subframe, and transmission. If you are lucky a wheel is way out of balance. If not then you have to look at all the steering/driveline, suspension parts and the subframe to make sure something didn't fail.
TankII
Bolton, CT
When I had someone else put new rotors on my '91, they put the early '91 rotors on which don't fit properly. Eventually, it found a way to seat itself, and the wheels came very loose.
I've had similar problems with broken belts and badly bent rims. Also, with lousy tires like Bridgestone RE760's which went out of round before the tread was half-gone.
