Dead temp gauge
SHON7
Quebec
I have no working temp gauge, the prvious owner said he changed out the sensor (sending unit) Is there a way to test it to see if it works or not??
MrRed
green 93 sho
MI
mine takes forever to move, like 10 miles or more, don't know if that helps or not.
SHON7
Quebec
No cause mine don't work at all, and it's a pain not knowing your engine temp!!
If you pull the wire off with the key on it should read cold. If you ground the wire it should read hot. Probably a bad wire.
crazy_canadian
Rattle-Mobile
Quebec
There's a different sensor for the ECU signal, that control the fan, and one for the gauge itself.
SHON7
Quebec
Ok so the one for the gauge is the wire coming of the sending unit??
