Dash lights gone
Eliw
Brooklyn NY
Well, not completely. I messed with my 89's fog light switch. Burned like two fuses and then afterwards lost my dash lights. I got them to turn on with the headlights by tapping the headlight power wire in the fog light switch and connecting it to the dash light wire in the same switch. I want them back to normal!!!! So, I need help :nut:
Also, if it helps, I have noticed that the dash does not dim when I try to dim the dash with the dimmer that also turns on the dome lights. The dome lights do turn on however. Also(2) the radio panel switches to night mode when the headlights are on. Does this indicate a problem at the dimmer? Thanks in advance.
