Dash cluster beep
DrewPenzkover
Ok first off I'm new here! I browsed through a lot and didn't see what I was looking for so figured I'd ask. 2010 sho I have a beeping coming from the gauge cluster. Seems to beep more when the car is off, but will also still beep while driving. Only thing I have found was about the air bag light being out will make it beep. My air bag lights works and comes on when I initially start the car. Anyone know what the deal is?
DrewPenzkover
Battery possibly? Check for codes in the PCM.
Funny you say battery just put a new one in yesterday since mine was starting to have issues! Unfortunately problem didn't go away. My livernois tuner and my efi live tuner don't pull any problem codes besides one for O2 sensor... maybe needs to be checked with better scanner?
AFAIK the Livernois tuner pulls codes from ALL modules, so if it is only pulling up the O2, that's all that is stored. BTW, the battery is controlled by the Battery Management System, which needs to reset each time the battery is changed. Either reset it using a scan tool, or let the car sit undisturbed for 8 hours after you turn the engine off. Either way will work.
Sure the keyfob battery is not going also? Do you have another keyfob to try?
