Darreli's 2010 SHO Dyno Video/Graph
LMSRick
Livernois
Westland, MI
ok here is the next step...... twin gt35r turbos. Supports up to 600 hp. 56 Trim,dual ball bearings allow for higher efficiency and much faster spool up. Oil cooled, and is setup with a external wastegate. now does anybody have the specs on fuel delivery? fuel pump? injectors? fpr?
I don't think there is physically enough room for larger turbos. Darrell spoke to Turbonetics and they may experiment with difference size wheels in the factory shell.
-Rick
Racer X
SHO Pilot, Retired
Connecticut
-Rick
Rick, please don't feed the troll.
well simple relocate the turbo... it dosent have to sit on top of the manifold.
This is my last can, y'all...
Troll spray
SHO U UP
SHO Guru
Virginia Beach, VA
Cam upgrades typically are not a very impressive mod when you're dealing with forced induction. Usually stock cams are sufficient.
I have to beg to differ on that. My stage 2 Comp cams in my truck helped create quite a bit more power than someone with similar mods and stock cams. Nonetheless, I doubt there will be cams available for the SHO anytime soon though.
86si
Lincoln, NE
How much power did you gain from them?
SHO U UP
SHO Guru
Virginia Beach, VA
IIRC, in the 30+ hp range. Another guy went with Trick Flow heads and stage 3 cams and had 53 more horses than I did. But then again, you must have other supporting mods to accomodate the use of the cams. Just bolting them in to a stock motor will not yield a great amount of power.
typhoon5000
Ferd Enganear
Shelby, MI
I would probably look in to running cooler E85 and over boosting them a bit just to keep that instant power.
The EcoBoost isn't a FlexFuel Motor. The ethanol will eat at all of the seals and I don't even know what it would do to the DI system. Is their a production FlexFuel DI engine out there?
86si
Lincoln, NE
Yep, i see that every time I fill up :)
SunDaze
Thanks Rick..... I'm looking forward to what you will be releasing in the very near future
PhantomX
Land O Lakes - FL
I'm very curious about your tune Rick. Some questions though if you don't mind.
1. I live in FL have you done any hot weather (really flippin hot) testing with this tune to see how it reacts. Turbo's hate heat and I just imagine the knock sensors going gonzo trying to keep down detonation, of course if that's the case the motor isn't going to last long
2. Have you been able to data log this thing yet, I seem to recall some discussion around there being no real data logging so you were really just shooting in the dark with some of the original tunes. Also I heard the PCM is crazy difficult with a stupid amount of parameters that even turbine specialists are having trouble figuring out, what puts you guys "in the know?"
3. I noticed your graphs aren't showing A/F what's that look like or are you even taking that measurement? I would be curious to see how lean/rich you are running the car as well as what the overall timing looks like. I did a lot of tuning on my old Terminator Cobra and getting the timing right was a bit tricky and if it was wrong, well bye bye 4V. I was lucky, some others weren't playing with boost is a dangerous game.
4. On a scale of 1-10 how "safe" is your tune, some people really push the edge with these, can you confidently say it has longevity to it and isn't going to pop a motor if your a responsible driver (had to throw that in because some people are idiots).
I would absolutely love to tune the SHO but I'm a bit paranoid with this new engine, new design and a departure for Ford to go mainstream with a lot of Turbo cars. All the N/A Mustang and Cobra tunes out there are tried and tested in thousands of cars over years of abuse and they still run, this motor and setup and PCM is all new and the level of complexity is high and I think Ford sent out a warning with it's TSB that they don't want people messing with it. The Mustangs are pretty bulletproof and unless your an idiot you can tune them all day and they will stay together (all 5 of mine did and nary a warranty issue) but this car is another animal and I don't feel like departing with $10k to put in a new motor.
Sorry for the dissertation but I just want to be well informed before potentially putting myself in harms way.
Thanks,
Bill
LMSRick
Livernois
Westland, MI
Bill,
I don't blame you for being cautious when tuning your car. I can assure you, our tune is somewhat conservative but makes excellent power. See my responses below in red.
We also get hot weather here. It has been in the high 80's/90's all week and we beat our car like we stole it on a daily basis. Our tune retains the factory knock sensors/settings.
SCT just released the software to datalog, but we were using our own proprietary software to log from day 1. All of the cars we street tuned were logged. I'm not saying we know everything, because there is a definitely a ton of parameters, but our tuner Dan Millen has been tuning for years and takes the time to learn the software and develop files that are safe whicle making excellent power
We do log A/F, again even all fo the cars that were street tuned had A/F monitored. We never post the A/F graphs, because everyone has their own opinion of what A/F should be, but again we tune conservatively while getting great power out of it. We will never tune anything on the edge.
I would say our tune is 6-7 out of 10. If you want something very safe, we could just do the transmission with reduced torque management. It makes a noticeable difference. I can honestly say, in my 7 years here I've never seen Dan break a car on the dyno. Obviously with OEM parts, there is no guarantee, but we aren't going to push a customer car to the edge.
Thanks,
Bill
Regards,
Rick LeBlanc
Livernois Motorsports
SpAz
Colorado
Hey Bob, they can put it on a SCT tuner for you.
we want time slips. we want time slips. we want time slips.
come on crowd help me out.
darreli
Run'n from BPD
Michigan
Sorry, had a death in the family so I couldn't make it last night. Be at the strip for sure on Wednesday and temps are forecasted to be in the low to mid 70s!:evilgrin:
SHODWN
Mother Threasa
Spencer,Ma usa
looks like you boys need to find some " closed roads" there to make some more videos next week..
darreli
Run'n from BPD
Michigan
Sorry guys, little slow to post. My best pass on Wednesday looked like this
60ft- 1.84
330'- 5.33
1/8 et- 8.3
1/8 mph- 81.86
1000'- 10.812
mph- 96.13
1/4- 12.91
mph. 105.86
temp was 77 degrees and that's with 100% torque management.
I picked up about a tenth and couple mph over my previous best with about 15 degree higher temp and the torque management back on which was completely off before. I'll have the torque management turned off this week and the Corsa on and we'll see the differences. The problem is I probably won't get that low of an air temp this summer.
SHODWN
Mother Threasa
Spencer,Ma usa
60ft- 1.84
330'- 5.33
1/8 et- 8.3
1/8 mph- 81.86
1000'- 10.812
mph- 96.13
1/4- 12.91
mph. 105.86
Don't take the Tq reduction off.. its rattles the trans out of the car.. This is very unsafe to do..
