This is ******* me off to no end. Absolutley everything has been replaced with new parts in the rear brakes: calipers, pads, slider pins/brackets, rotors, rubber hoses. The entire system has been flushed, and re-bled correctly. Ebrake cables are functioning properly and not sticking on either wheel.
The RR is messed up still. It's either the entire loaded caliper set is crap (from NAPA), or perhaps the stupid brake bias valve is messed up? The RR caliper, bracket, and rotor are all rusted to ****. The LR is no where near as bad. I just did all the work 3 weekends ago. The RR sounds like it's getting rust particles or brake dust in between the pads/rotor. Everything is fine if it's raining out, meaning good firm pedal and no brake dust squeal. I think the caliper isn't releasing all the way. I know it's not the ebrake cables because it was doing this before I hooked them back up. It's not releasing just enough to wear on the pad I think. It's not hot or anything.
Am I right in saying it's either one of two things: Either the caliper/pad set is just crap to begin with (and I should go back to NAPA and demand better parts
), or the damn bias valve is not working correctly?
Thanks in advance. Hopefully I don't have to **** my SHO this week.
