Car is an '89 SHO, 275,000 mi. Just oil change and 60K's although I think she's going to need a valve job and the rings / pistons may need to be done - I need to do a compression test.
OK, I understand the mechanism for the chime and how it works.
I remember that that black tab with the contact on the end bent eek! up when it jammed as I pushed the cylinder lock into the other cylinder, before installing the assembly into the column.
I then bent the tab downward - but I may have forced it down to much as it then will contact that little grey/black metal piece (that comes up and makes contact with the tab when the key is in the cylinder) all the time even when the key is not in.
Looks like I messed up.
I'll remove the cylinder and try to fix it.
But I still need to solve the problem that the key/cylnder must be forced very hard at the end of the stop position before the switch will start the engine.
If I leave it this way, I'll just break another key in the cylinder.
BTW - who designed these keys in Ford.
My ignition key is cut symmetrically from the top and bottom (I guess like everyone's) so that the key can be inserted into the cylinder either way. But at one point the cut key blank necks down to 1/8" because of the deep cuts from the top and bottom. This minimum "width" point on the key is just at the point where the key stops entering the cylinder. rant
So guess what - the weakest point on the key will be subject to the maximum torque / moment / twisting force from my fingers as I turn the key. headbang
Thus the key will easily break at this point.
Who's the ***** at Ford that designed a key cut such with so much metal removed that the width is ridiculously small?
If they just cut the jey from on side (thus not giving as much flexibility in inserting the key) the key would be much stronger. headbang
Also, what happened to the "wings" on the cylinder lock which you could turn with your fingers thus not putting ANY pressure on the key - your fingers turn the "wings" and are not on the key.?
That's how I remember the older cars.
Why do they make things worse instead of better?!!
