You'll need at least:
13mm 12mm, 10mm, 15mm sockets and wrenches
Various 3/8in extensions
The head bolt hex socket (metric, forgot the size)
Flat head screw driver
You'll want to have
Paint pen
Bandaids
Soda or beer
Remove the negative battery cable!
Take off intake (and assorted equipment/wires/hoses)
Take off passenger side wheel
Remove tension from timing belt
Take off the top timing cover
Mark the belt in relation to the timing marks on each head cam sprocket
Take the belt off the cam sprockets
Drop the Y pipe
Relieve the fuel pressure
Remove the fuel rails
Remove the fuel injectors
Remove coil pack and bracketry
Remove the coolant lines from the thermostat housing, and the various assorted hosery and sensor connectors
Take out all plug wires and plugs
Remove the valve cover bolts and valve cover
Take off the head bolts
Take off the heads (the exhaust manifolds can be taken off either with the head installed or with it uninstalled
