cv shafts
rbrthrly90
frederick
when repacing the tranny i need to take the have shafts out. do i need to replace any seals o rings or anything when i put them back in the trans. if so what are they called is there a hardware kit or anything thanks for your replies
Sho-Driver
Peter Pan
The Garage.
If your seals are original, it would not hurt to replace the axle seals. These hold fluid in your transmission. If they are not leaking, you don't necessarily have to replace them.
rangerj
Brunswick, Ohio
If your replacement transmission is a used trans, then replace the axel seals. The seals a relatively cheap and easy to replace when the trans is out of the car. The outer part of the seal that contacts the trans case should be coated with a thin coat of anerobic sealer. The rubber seal itself should come with a bead of grease around it.
Be careful inserting the axels into the seals so you do not cut or otherwise damage the seal. Check the axels for any burrs or rough spots where they are inserted into the seal. Make sure they are clean and apply a light coat of trans fluid just before you insert them into the trans.
