I have a 95 MTX and replaced the CV axle on the drivers side. Why, well long story short, I pried to ******* it when replacing the struts and pulled the joint apart and ruined the needle bearings. Anyways when I removed the old CV axle there was about a 1/2 quart of fluid that came out. Can someone tell me what the fluid is so I can replenish it? I have been told for a manual transmission, it was transmission fluid and can be filled by the plug on the transmission next to the CV axle shaft I removed. I remember seeing a plug, so that makes sense however before I put any fluid in, I would like for someone to confirm. One note is before I removed the CV axle, I put a quart of Royal Purple oil in the engine as it was low. The fluid that came out of the CV hole was very similar to the color of Royal Purple which has me confused as I would have expected red for transmission fluid. Thanks for your feedback.
