SHOoff89
OK, before I get neck deep into relpacing stuff I thought I would run this by you guys first. My 91 with just over 83k on the odo has started cutting out at around 5 to 6 thousand RPM, almost like I am hitting the rev limiter or something, but its not. It will rev past that smoothly it if is only at partial throttle though. Any chronic fail parts I should check first? It has had a 60k within the last 5k, but I did use non-motorcraft plugs and I didn't replace the wires (I know, I know) but I was doing this on a budget. Everthing else was replaced though. Any ideas?
