If available strut compression travel (i.e. resistance to bottoming out) and lack of rubbing noise is more important than lowering the front of car by a paltry 0.35”, then I recommend the 89-11/90 and 94-95 Front Strut Bearing for all cars. Since this would be the most important to me, I would recommend the 89-11/90 and 94-95 Front Strut Bearing for all cars, period.
If lowering the front of the car is more important than eliminating the strut noise and increasing available strut compression travel, then I recommend the 11/90-93 Front Strut Bearing for all cars, but bear in mind that you may have to add spacers to eliminate rubbing noises, and then you increase the ride height without any corresponding increase in compression travel.
