Cruise Control??
SHO_ROLLER
Florida
Last night I was coming home when I pulled over to get some gas and a Red Bull (it was 1am). My cruise control had been working all that night but when I tried to use it after stoping, it didn't work :mad: ! Any idea what it could be? Fuse maybe?
Anthony shrug
Check to see if the cable from the servo popped off the throttle.
Check the vac hose to the servo.
Make sure your brake lights aren't stuck on.
Test your horn to see if it works, if it doesn't, troubleshoot that circuit and you will probably fix the cruise problem.
If these checks don't reveal the problem, you will need to perform the diagnostic procedures in the manual to test the switches, the VSS, the servo, clutch and brake cut outs, and the ECA.
Good luck.
<small>[ March 19, 2003, 09:25 AM: Message edited by: projectSHO89 ]</small>
JaySHOguy
Bellingham,MA
I completely removed my cruise control crap :)
Stripping little peices of my car at a time wink
89 black SHO mtx
bean station tn
check the clutch switch i had a problem with it slipping back??? never did figure out how that happened anyway i just unplugged it and the cruise works fine now. just don't unplug the clutch start plug.!!! no starts are no fun :( :confused:
