Cruise Control.
94MassSHO
Buzzards Bay
My cruise control stopped working after I had the tranny/clutch/flywheel replaced. I was wondering what the problem would be and hope there is a simple solution.
Thanks,
Dan beer
twr
whoohoo
half-way there, I think.
Speed sensor may not have been plugged back in. I have also heard that it is easy to disconnect the vacuum line at the cruise control unit under the hood.
rangerj
Brunswick, Ohio
Ditto
Check connections at the speed sensor, cruise control unit electrical connection and vacuum connection, and the cable connection at the throttle body.
Follow the vacuum connection from the power brake unit or the intake manifold ( near the throttle body) to the cruise control servo and make sure all connections are good. rangerj
