Key On, Engine Off and Engine Running tests can check the IVSC system by testing its functional capability and verifying that various sensors and actuators are connected and operating properly. The KOEO and KOER IVSC tests are functional tests which only detect concerns present at the time of the Self Test.
To activate KOEO IVSC test, do the following:
1. Place transmission shift lever in PARK.
2. Hook up your multimeter in accordance with the regular EEC-IV code-pulling procedures (see
http://www.dalidesign.com/hbook/eectest.htm)
3. Turn ignition switch to RUN position.
4. Within 10 seconds, press speed control ON switch.
5. Press speed control OFF, COAST, ACCEL, RESUME buttons; tap brake pedal once.
NOTE: Do not depress throttle during KOEO self-test.
6. Observe and record all Diagnostic Trouble Codes indicated.
DTC 452 = VEHICLE SPEED SENSOR (VSS) PROBLEM.
(Note: This code is actually stored by the regular EEC-IV monitor(s), not the IVSC system monitor. Hence, it’s probably a good idea to run the codes in the regular manner before doing the IVSC system test in order to see if this VSS code comes up).
DTC 453/454 = DOES NOT HOLD SPEED DURING DYNAMIC TEST
Possible Causes:
- Speed control servo.
- Vacuum hose connections.
- Speed control vacuum reservoir
- Speed control vacuum valve.
DTC 455 = SPEED DOES NOT INCREASE DURING DYNAMIC TEST
Possible Causes:
- Actuator cable.
- Speed control dump valve adjustment.
- Powertrain control module.
- Speed control vacuum reservoir.
DTC 456 = SPEED DOES NOT DECREASE DURING DYNAMIC TEST
Possible Causes:
- Actuator cable.
- Throttle shaft and linkage.
- Throttle position sensor (TPS).
DTC 457/458/459 = SPEED CONTROL SWITCHES
Possible Causes:
- Speed control actuator switch assembly.
- Air bag sliding contact.
- Wiring harness.
DTC 567/568 = SERVO SOLENOIDS
Possible Causes:
- Servo vent solenoid.
- Servo vacuum solenoid.
- Circuits SOL+, SCVNT, and SCVAC.
