Cruise Control Issues...
SHOkid13
Take it to the track
Temecula, CA
My cruise has the tendency to keep the speed of my car within a 5mph range. It accelerates the motor and then coasts and accelerates again. It can't hold the car at a constant speed... It gets almost sickening after an hour drive. Plus, my gas mileage suffers. Any suggestions on where to start troubleshooting? :shrug:
Rockledge
Pluggin' away
Connecticut
Vacuum leak maybe? Have you checked the hoses/connections to and from the servo, etc?
SHOkid13
Temecula, CA
I haven't checked for a vacuum leak yet... I read somewhere else on here that '93 up uses a servo and not vacuum... is that true? I guess I need to go look... ;)
Rockledge
Pluggin' away
Connecticut
MTX speed control uses vacuum. ATX does not. If you look at your servo you will see vacuum lines coming off of it.
SHOkid13
Temecula, CA
Ahhh, got it. Okay, I'll check it out. Just use a vacuum gauge on the fwy?
