cruise control differences? what drives them?
'92SHO
I am curious to know what the differences between the Mustang and SHO cruise controls are. I changed the rearend in my 5.0 and did not have the correct speedo compensation gear for the trans right away, and until I installed the gear in the transmission, the cruise did not work. (Neihter did my speedo) I am curious to know if this is the same for the Taurus, and also as to what drives the cruise. I thought it was vaccuum on one, and electronic on the other, but why would it not work is the speedo ger is not in the trans of my Mustang?
SilverSHO
cartersville
I believe the SHO cruise control is vacuum-actuated, and the speedo gets its info from the vehicle speed sensor (VSS), which is located on top of the transmission, IIRC.
As for the speedo gear in the Mustang, I would imagine that the speedometer takes its reading from that, and not a VSS as on the SHO. If the speedo can't get a reading because there is no gear there, then the cruise control probably won't work (if it is electronic). Of course, I know nothing about Mustangs, so this is all hypothetical. :)
projectSHO89
SHOless In St L
Ford has used the VSS for CC operation as long as I can recall and still does, AFIK.
Some CC systems are all electronic. That means only that the servo actuator is driven by an electric stepper motor instead of a vacuum motor. The rest of the system is identical in concept and very similar in implementation.
They all rely on the output of a sensor to determine what the relative ground speed actually is.
Steve
Dave Kegel
Chicago suburbs
Yes, the ATX SHO has the electronic cruise. One tap up or down changes the speed by 1 MPH. The MTX SHO uses the vacuum type.
Dave Kegel
