Crimped heater hose
KyngofPop
Freday-day
Charlotte NC
Guys of course wedded SHO bliss doesn't last too long haha. Had a coolant leak from one of the molded heater hoses leaving the block and headed to the heater core. Here is what the hose/pipe looks like:
Now I've checked O'Reileys and they of course don't have the original piece, so what do I do with this? How do I fix it? Sorry for the large pick, not sure how to resize. Thanks gentlemen.
elarm1
Maryland Native
Woodbridge, Va
I took that metal line out a long time ago to avoid this issue they sell a rubber hose to replace it with
LJRuddy
Pop lock n drop
Poaceae fields
Use an oxy/acy torch. Makes quick work of the hose... And the engine block if you need to do rod bearings.
KyngofPop
Freday-day
Charlotte NC
Lmao@ LJ, Nah the hacksaw made easy work of it. Im flushing the coolant as we speak and ITCHIN to take a test drive.
dohcsable
Gold Calipers>*
Indiana
just don't put that PITA bolt back in.....it'll make things easier in the future
dohcsable
Gold Calipers>*
Indiana
I actually had the pipe itself fail(hole in it!?!), but aside from that bolt, it was fairly easy to do with the intake off. I think I have 3 or 4 of those pipes as spares right now too....lol
Best Sho
Hudson Falls, NY
It's not affected. You just put new hose on the metal pipe.
Thanks K-Dawg, but now the other question I'm asking is how to get to that bolt that holds the tube to the engine for the Heater Inlet Tube?
Here my link --http://www.shoforum.com/showthread.php?p=1273439#post1273439
So far I've only seen 1 person say they pulled the intake off! That it was easier that way. I'll do that if need be but I was trying to see if anyone had another way that was not that lengthy, well short of replace the whole tube with hose!!!
Thanks
