Denny
Taurus Homeland
Interesting find today!
The SHO has been sitting for two days now. I went to check everything underneath. I found leaks, but not coolant. One is my power steering cooler leaks, and it looks like the front crank seal is leaking on me? Is it possible to install those wrong?
However, I was doing some work today, when I finished, I found that the hose that runs off of the reservoir tank was squished up against the AC line, so I went to unkink it, lots of coolant that was in that hose ended up falling to the ground. I opened up the radiator...the level had gotten low, couldn't see anything, filled it up about 1/10 of a gallon, then topped of the reservoir. No leaks found yet after a spirited half hour drive session. Could that kinked hose have caused problems?
