******* coolant
zblackbeast
SHOtarded
Omaha, NE
Well. Under the throttle body where the block meets where the coolant OUTLET(this is the edit) tube meets is ******* coolant. WTF do i do to fox it. is it a gasket or what?
zblackbeast
SHOtarded
Omaha, NE
I think it might be by th heater lines from the rear head.. is there a gasket back there??
Storm-Chaser
Shit Louis
There are at least five possible leak-points in that area. You need to better determine where the leak is. Do a coolant system pressure test after the motor/exhaust has cooled-off, which will allow you to better search/feel for the leak.
:burnout:
HootUSMC
oh, that guy
Boston, MA
I'd talk to your Doctor is you are ******* coolant. You may overheat so take it easy.
zblackbeast
SHOtarded
Omaha, NE
Ok, ill make sure to get some bed rest for the next few days... haha.. ok. im gonna go out in a short while here to find it..
zblackbeast
SHOtarded
Omaha, NE
There were no pinch bolts for either of the 2 Connectors under the IAC. But it seemed like there was more coolant than either of those two lines can pump. idk. there is now a hole in one of those lines, so im going to replace those and put some tube clamps on them and see if that fixes it tonight.
