rocker231986
learning
hey guys as the title say i have a coolant leak i cant find. I went autocrossing with it and i noticed between runs a coolant smell and sure enough there is coolant sitting on the top of the transmission in puddles but no serious coolant lose. which i thought was puzzling
after doing a little investigating i noticed that the thermostat housing was covered in dry coolant but i cant see it leaking its like it leaks under pressure.....the smell is strong coming from the top of the motor.....someone told me that i could be a head gasket but its not showing any signs of a head gasket....no smell from exhaust and no coolant in oil and its not over heating can you guys plz give me a idea where to look.........thanx guys
It sounds to me like this guy's coolant leak is somewhere else from the fact that he stated he was puddling on the tranny. Basically, if you see dried coolant, you had a leak. Odds are it is pressure related IE) when the system is hot and pressurized.
