Coolant leak developed
362104
DV8
43*46'30"N 88*26'41"W
I am guessing it happened Saturday night on the way home form work when it was like -15 degrees. Not really suprised by this considering I have the original hoses from 1994. I bet the pressure was off the chart.
I am taking her in Wed. to have pressure test done. Hopefully, it's nothing major, just a couple hoses replaced.
Anyone exp. issues with the CANADA like cold.
Keith:salute:
FREAK_SHO
Wisconsin
From where is it leaking, approximately? May Just be the radiator leaking around the plastic end tanks.
black92
Wisconsin
Lets hope its not the waterpump. But yes I have exterenced a leak in cold weather. And it was the radiator.
black92
Wisconsin
The water pump is on the passenger side. Coil pack is on the drivers side. That hose is the upper radiator hose.
smokin joe
Milwaukee WI
Yeah I thought mine was eating coolant because ever since I got it, it would SLOWLY go through coolant and it never smelt or left any marks when parked but when it got cold out it got a little worse and I found the leak on one of the hard lines on the back of the motor the coolant was just sweating out of it
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
My car eats coolant and oil.. very quickly no drips no smokes .... and its not going into the engine.. where is it going?!:shrug::banghd:
black92
Wisconsin
Brandon that sounds like head gaskets. Are you sure its not getting into the engine?
black92
Wisconsin
Mrhappytuzi said:
dude ive been checkin like crazy.. When ever it decides to uhhh.. warm up ill increase my investigation...
You would have to remove the heads to investigate that right.
FREAK_SHO
Wisconsin
it may have slushed up a bit do to the cold, causing a bit more pressure, which caused your leaky no more...
bmytych
