Mr95Gl
Mr Tire Iron
Yesterday I decided to take the SHO to school, because I was running too late for a final to take PT. On my way there, the throttle felt alittle different. I had just filled the tank, so I figured it may have been bad gas. Now it was about 20 deg yesterday, I saw some smoke from the rear, but I figured it was exhaust fumes from my 5K blast. Then the low coolant light came on, and I immediately pulled over. Came to a full stop, and enough smoke was coming out of the engine bay to signal fire house from 15miles away. I pop the hood, and there's antifreeze splattered on the firewall. It's 4:50pm, and outside is dark, and the hoodlight blew(been meaning to replace it).
Check the resevoir and it's empty. Fill back up with antifreeze and limp 2 miles to an autoparts place. I thought it was the heater core hose, because I had the heat full blast so I turned it off (big mistake) bought another bottle of antifreeze, poured it in, and limped home. This morning, I go out to further investigate start the car, turn the heat on and it turns out the leak is coming from a coolant hose the runs under the throttle body, and goes into the engine. Talk about a PITA to remove. I'm not the most mechanically inclined, and it took me 45min, just to remove the godforsaken hose. Removing it from the throttle body was nothing, but to try and wiggle my hands down in there with pliers to remove the hose clamp, christ!!!!
My question is. . . . . from the firewall theres two hoses. The one more to the driver side is the heater core hose? It's a rubber hose from the block, then turns into a metal line, then back to a rubber hose going into the firewall. If so, do they sell replacements for the metal line? Same goes for the other hose on the passenger side of the firewall. Reason for asking is because they are completely corroded, and very rusty and sooner or later they are going to go. Next one is, those clamps that they have on the metal lines. . . . . do I have to cut them off, or can they be removed with a pair of vice grips? Guys, any info will be very appreciated! I'm about to go back outside to get the hose for the TB and put it on. Also, could the slight difference in throttle response be affliated with that hose? Thanks alot!!
Frantzdy
Frantzdy
