Computer Removal Problems
Dr.Evil
No Dif Pin!
Sparks, Nevada
I just got my new B9B computer w/ LPM for my 90. I have had the current B9B1 computer out many times before with no problem. Well I go to take it out to put the new one in, and I cant get it to come out. The bolt comes all the way out and the comp. is still stuck in there. Is there some sort of double screw in there? If so, would putting some lock tite and then screwing it back in and trying it again work?
thanks for any ideas...
<small>[ August 11, 2003, 04:05 PM: Message edited by: Dr.Evil ]</small>
Dr.Evil
No Dif Pin!
Sparks, Nevada
I don't want to push the black plastic backing out by pushing on it...or is that ok to do?
therockjdb1
Oklahoma City
I just replaced my computer in my 90 SHO and i had to yank really ******* the computer and my friend was on the other side pushin...gettin it back in is a pain in the butt also
shobote
Naperville, IL
just did mine too; remember there are 2 plastic lock in tabs on each side of the computer; may have to jostle it side to side until it comes loose, and maybe eat an extra bowl of wheaties in the mornin'
Dr.Evil
No Dif Pin!
Sparks, Nevada
There is nothing on the side of the comp that for the clips to catch. I tried prying the clips out of the we with screwdrivers and it still won't come out. It come out a little, but not all the way. Anything I overlooked? shrug rant headbang
Jr's Sho
Moss Point, MS
If it's anything like a Gen. 2, a pair of adjustable pliers or a monkey wrench will grip the thing. Just make sure you have it real tight and pull. Trust me, it'll come out. It's most likely stuck on that gasket material.
Dr.Evil
No Dif Pin!
Sparks, Nevada
I just don't want to rip the whole assembly through the firewall or break something. Then I would be really screwed!
Bizzy
spray the gasket area from the engine side with some type of silicone based spray lubricant. a quick shot and let it soak in, then the coumputer should slide out very very very easy. make sure you use something that will not breakdown the foam of the gasket, not WD40 or PB Blaster.
