Complete Car Bushings?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
dilligaf:
I'm also in for the right price!
Can we get some info on this? Price? What it includes? I need the Bushings for the tension/compression Arms in the front, along with every other suspension bushing in the front. I'd be interested in a whole car kit, and I wonder if we could have an option (for a little extra) to get subframe bushings (police, aluminum, delrin, whatever). Thanks!
SHODWN
Mother Threasa
Spencer,Ma usa
Why are those kits listed? Anyone that has orderer them should cancel the order.. Thoose are NOT drect replacements but a Poly bushing with a steel U bracket, it will fit on the front but not useing stock brackets. The rears are the same, but you have to drill holes in the frame and try to nut it while in the frame.
Check out my posting on V8SHO .com..
Also none of that will work on a GEN 3 folks
rlw001
Reading, PA, USA
91SHO:
I would be very interested!!! Needed badly!! Let me know.
Putting the final touches on the "Group Buy" right now. This package will encompasse more than just sway bar bushings.
Poly front sway bar to body bushings,
TPR rear sway bar to body bushings,
Stock (1/2 TPR) front tension strut to subframe bushings,
TPR front tension strut to lower control arm bushings,
TPR rear tension strut to body bushings,
TPR rear tension strut to knuckle bushings,
there maybe a few more items.
I'll keep you guys updated.
SHOfun 93
Euless, Tx (Fort Worth)
Okay,
I have a question. I am going to change out the terrible stock struts/springs with coilovers from IPT in the next few weeks. Is there any bushings that I should/have to purchase to ensure that I don't have to take them back out again when I need to replace them? Do the coilovers come with any bushings at all? Everything on my car as far as suspension goes is original, so I need to freshen up mine badly so I am VERY interested, but need to know if I need to wait on coilover install for bushings, and what bushings they would be. Thanks..
<small>[ October 06, 2002, 12:39 PM: Message edited by: Jeremy Hohn ]</small>
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
rlw001:
Any idea yet on price? I need this stuff badly, and it sounds like it should replace everything thats clunking, moving, and worn out on my car. Thanks for putting this group buy together, it sounds like it will do a lot of people a lot of good! I know it helps me. Any chance we can also buy subframe bushings with this kit for a reduced price? What vendor will this be done through? Thanks a lot!
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Jeremy, the coilovers come with everything you need at the time of install, meaning you do not need to buy anything to put them on and drive, BUT, I would highly recommend ASB upgrades and new poly/TPR bushings. Get in on this group buy as it covers all you will need. Just replacing bars and bushings alone will make you car feel like another animal, then with the coilovers on top of that...WATCHOUT!!
Hey, going to Madison next year? We could have a sweet TX/OK caravan.
Toolman
Boost it!
Also, since the coilover springs are so much shorter, you can access bushings at a later date with much more ease. Call me if you have any questions (918.541.0219). You are going to love your car all over again! What spring rates did you get for the auto?
rlw001
Reading, PA, USA
Any idea yet on price? I need this stuff badly, and it sounds like it should replace everything thats clunking, moving, and worn out on my car. Thanks for putting this group buy together, it sounds like it will do a lot of people a lot of good! I know it helps me. Any chance we can also buy subframe bushings with this kit for a reduced price? What vendor will this be done through? Thanks a lot![/QB]
Josh (SHO NUT) is calculating the pricing structure on 25 buyers.
I know I need to "freshen up" my 85K suspension.
I will ask Josh about SFB option.
Thanks.
Bob
SHOfun 93
Toolman:
I dunno...whatever Shawn hooks me up with, but I believe he suggested the intrax springs with Konis. Thanks for the tips and I will keep your number if my friend and I have any troubles! I DO plan on making the convention next year, and will be glad to make the caravan. Should have the SHO completely freshened up by then!
Toolman
Boost it!
I am using the Eibachs on mine and am very pleased. I belive my spring rates are 600f/350r. Looking forward to the caravan!
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
rlw001:
Thanks.
Bob
Thanks for your effort in getting this together. Your efforts are appreciated! Count me in!
SHOfun 93
Toolman:
Just PMd shawn and he told me 650/350 on my spring rate. Looking forward to it too! My sho should look like a white clone to yours when all is said and done!
Toolman
Boost it!
Sweet. Hope you can make it up here for the Fall Drive I have planned with the SHOklahoma group and some friends. Probably be mid-Nov.
SHOfun 93
Depends on basketball season. The NCAA has be flying all over. If you get me a solid date, I will try to keep it open to make it. thumbs_u
