MerkXRTurbo
Hey everybody, I just thought I'd post the info that I have learned to anyone else interested. I CC'd a head last night. The SHO combustion chamber volume is exactly 35cc.
According to the Ford manual the 3.0L SHO motor CC volume is 47-48 cc and for the 3.2L it's 46.7-48.3 cc.
Did you measure a compressed Head Gasket?
I must be confused then. If the engine is 3l, that's 3000 CCs which would be 500CCs per cylinder. That sounds about right because 3000CCs ≈ 183 cu in. What am I missing?
edit: Wait a sec... is the "combustion chamber volume" different from the cylinder volume in the way that the cylinder volume includes the entire range of the piston travel, and the combustion chamber volume only includes the volume of the cylinder and head at point of combustion? If so wouldn't that change if you use higher or lower octane gasolines?
Where exactly did you find this info? I wasn't able to find it anywhere, not even in the PDF SHO engine book.
