cold start problems.....
zach44102
BIG TURBO
Georgia
for the past couple days since it has been getting cold outside i have had a issue....the car will start fine and idle fine but once you go to give it gas to pull out the rpms will tank and want to stall, and if it stalls the car will not start back, will turn over but will not start...if you let off the gas rpms return to normal, if you slowly give the car gas to raise the rpm's before taking off the car will take off and drive normal.....this only happens when its cold around 40 degrees or so, once the car has ran for a couple mins or its in the afternoon where like today its 60'ish it has no problem idling nor taking off....what could be the culprit, i have a new/clean maf, recent taylor wires and recent e3 plugs. i was going to pull the IAC but seems like that would not be the problem....:thankyou:
