I just changed out all 8 coil packs with ebay coilpacks (8 for $137). And all 8 spark plugs (Motorcraft). 2 of the rear bank spark plugs had oil on them. What causes that? Also as I was tightening the bolt to one of the coil packs... I got a little over zealous and it cracked the coil pack where the bolt goes thru. The other bolt tightened up fine. Will this be OK? Also NONE of the rear bank connectors "locked" into place when I connected the wiring harness to each coil pack. Have I just entered a NIGHTMARE?
btw... it still runs a bit rough!
